TwinTurbo.NET: Nissan 300ZX forum - I've had to use a floor jack handle with my breaker bar once
Polish
on July 21, 2015 at 12:02 AM
Thanks for the input guys >>
posted by WE350Z
on July 20, 2015 at 02:18 PM
Also I know it sounds silly but be 100 percent sure you're LOOSENing the plug. It is easy to get all disoreanted laying on your back down there.
Trans Fill Plug Stuck
WE350Z
03:00:15 07/20/15
Re: Trans Fill Plug Stuck
MaxxAction
07:42:52 07/20/15
Yeah I would also suggest not using a torque wrench
-Grimm-
09:39:50 07/20/15
Also
-Grimm-
09:41:29 07/20/15
I had a problem with the differential plug on my Infiniti.
not4resaleZ
11:59:03 07/20/15
pipe wrench won't work these are 13mm hex bit (n/m)
WE350Z
14:53:09 07/20/15
Mine took a 13mm square bit. It was too hard
not4resaleZ
18:25:06 07/20/15
Dang - $30 bones for a socket! >>
WE350Z
18:50:15 07/20/15
That won't work. Need Square. I think I rounded mine
not4resaleZ
11:44:14 07/21/15
So I need to buy the $30 socket or risk rounding it with the
WE350Z
12:23:30 07/21/15
You can try the 1/2" but you do risk rounding it out.
not4resaleZ
13:06:54 07/21/15
Thanks was wondering where to apply the heat, as for the >>
WE350Z
17:37:07 07/21/15
If it's beat up, get a new plug. I'd just torque to spec. (n/m)
not4resaleZ
17:30:43 07/22/15
got it - i think mine is OK but I'll see how it looks after>
WE350Z
14:36:10 07/24/15
I had no idea there was a socket for that
ZXRider
13:27:02 07/23/15
yeah - 1/2" drive works out to 12.6mm which is not correct >
WE350Z
14:35:27 07/24/15
WE350Z
14:18:01 07/20/15
I've had to use a floor jack handle with my breaker bar once -
Polish
00:02:37 07/21/15
Left loosy! (n/m)
WE350Z
12:19:34 07/21/15
I'm hoping i can get my breaker bar on enough of an angle >
WE350Z
14:42:44 07/24/15
